oil leak
541 Views 2 Replies 3 Participants Last post by  NickR
got a 93 mx6 ls oil leaks any help?!?
got any idea where it's coming from ? How much oil is leaking ? Put a piece of cardboard or paper under ur car after u park it and see where the oil drops, that's how I usually trace leaks
The most common places for leaks are:
1. the oil pressure sensor, which is close to the oil filter, between the filter and the alternator (looks like a spark plug screwed into the block, with a single wire coming out). Replace it immediately, because it can suddenly dump all the oil out the engine.
2. Valve cover gaskets. Oil slowly leaks down the block, and into the spark plug wells.
3. Oil cooler O ring. Just above the oil filter is the oil cooler.
