i don't think old oil would set off a sensor, at least mine doen't tell me when i need a change.. but odds are it could be a sensor.. have you checked your ECU for anyother codes?
The light is for low oil pressure, I'd suggest looking into it for obvious reasons.
well i found the problem. i forgot to mention i had just swapped this motor in out of a 93 probe. the probe has an oil gauge and the mx6 just has a dummy light...soooo the sensors are diffrent. i actually took out the stock oil sensor and hooked up an aftermarket oil gauge
Thanks for everyones help and suggestions!
