Guest
·Heres my story, over the last couple of months everything that could go...HAS!! It started with a new set of tires ($400) then the rear brake calliper jamed on, so a new set of pads were needed plus work on the calliper ($150), then it was time to have the cam belt changed ($300), then the clutch decided to start slipping ($300)then I got a flat tire...the nail had gone through the wall and screwed it totaly($100) now the front brakes need replacing and something weird is happening with the steering...it's much stiffer than it use to be and when driving really slow and turning to the right I can hear a scrapeing noise. If you have any ideas on the steering issue let me know...or for advice on the other issues I'd be happy to help!!
