Also...
If you use the search feature you can find this has been explained many times: Here is my explination from a while ago:
Mono-Wiper Mod.
Just take the passenger wiper off completely (you pop the little black plastic circle out, which
will expose a nut, just use a socket to take the nut off, then just pull the entire arm off--it's
easiest to get off if you put the wiper in the upright position away from the glass)
The next step is to take off the driver's side wiper the same way you took the passenger side
off. Once you take it off, put it back on where you want it to stop. It has little teeth, so you
can put it back on however you want it. Just make sure you put it far enough over the
passenger side so it doesn't go down and scratch your hood.
I reccomend a 20" dual blade wiper.. and some spray paint the color of your car! If you have
any more questions, let me know!
Alex
