Status
Not open for further replies.
1 - 20 of 58 Posts
I need a new clutch, I am looking at the ACT's. I will need to get the flywheel resurfaced, but the thought crossed my mind of swapping out the flywheel for a lightweight like Fidanza. Anyone who has a Fidanza, or equivalent, what do you think of it? and if possible, do you have any dyno sheets of before and after install?
In general, I am wondering if the lightweight flywheels are worth the money that they cost? I would rather not start a "In Theory" discussion. I would like to have good hard facts from people who OWN a lightweight flywheel, and it is INSTALLED on an MX6 or Probe, specifically the F2T.
not on my car, but on Sigmafours that i have been in many a time. the car feels more like a race car. the engine is a hell of alot more responsive. when you touch the pedal, the engine just comes right up to 3-4K with what seems to be no effort at all.
i wouldnt do a clutch without putting in a fidanza, first car i did it too was the tiburon, world of a difference, the f2t responds even better, there stronger then stock ones, and revs so much nicer.
one of the things I was worried about was over revving due to the lightened flywheel, I'm sure it would be pretty easy to do if you didnt pay attention ie: lined up at the track with a big bad V8 that you know you can smoke, that has been smoking everyone allnight. That situation could easily turn to nervous, overanxious, I really want to get a good launch and good run and smoke this Mustang Cobra...and all of a sudden.....REDLINE:eek:
depending on the condition of your motor, that could be a whole new headache, granted you wouldnt/shouldnt/probably couldnt smoke a Cobra without a decent rebuild and a good amount of mods, and probably shouldnt try but, ya know how that goes :lol:
so where have you found good lightweight flywheels? I know about the Fidanza and have heard of a few more, what kinds have you guys heard of for the MX6 and Probe? what kind of dollars are we talking? and where did you buy them?
Don't believe the rubbish from SCC. Lightened flywheels do not CREATE any power.
A lightened flywheel is a two edged sword. Yes, it does allow you to rev the motor up faster due to the lightened rotational mass, but....
The flywheel is used to help keep the engine balance and momentum. By lightening it, your throwing your entire crank off balance which could very likely cause bearing problems in the end run.
Also, Your engine speed will fall faster as well, and thats not usualy desired.
The flywheel is balanced separately from the crank, so changing the weight of the flywheel shouldn't matter unless it is not balanced. You can say that it wouldn't absorb vibration as well, but that's the harmonic dampner's job anyway.
Also depending on what you're doing, having the RPMs drop quickly could help, especially if you have problems rev-matching on turns or when up-shifting.
to keep on topic, SPEC clutches makes an Al flywheel for less than $400. They even sell ligthened clutch assemblies. i'm going to be going ot them for my next clutch, and basically being a guinea pig for some of these things (good value or cheap crap, only experience can decide). they're at www.specclutch.com . Lemme know what you decide on, Damian, since I'm in the same situation but you might be doing this before I do.
if you can afford to buy one then buy it. i payed $345 shipped from www.rr-racing.com for mine. you can definetly notice a difference. in first gear when i hit full boost the tach needle would climb so fast i could barley see it. but it does have some down sides. nothing major to me. like since its lighter there is less momentum of course. so you have to use the clutch differently. it takes a little getting used to. i killed it the first couple of times. as for the revs dropping faster. yes they do, but whenever i raced at the track i would shift so fast they didnt have a chance to fall. plus i noticed with the zombie chip, after i would depress the clutch the revs would continue to go up slightly. lightweight flywheels wont make your car super fast. i would say it changes the way it feels. i like the way it feels.
Butt dyno only. For an extended conversation on this topic (with the odd hint about why a dyno plot will not show any improvement) read this thread.
Oh, I do so much hope this thread turns into something like that.;)
so getting back to Flyswat's idea of throwing off balance, what do you think about the lightweight crank pulley? performanceprobe.com sells one for $105 and it stays the stock size but is made of aluminum and weighs a little less.So what do you think about this scenario: stock flywheel & lightweight crank pulley? lightweight flywheel & stock crank pulley? lightweight flywheel & lightweight crank pulley, I'm more interested in ideas on the latter, I plan on getting my motor rebuilt, but if I am going to be adding things like flywheels and crank pulleys (basically things that are a PITA to do) I'd prefer to do it all in the same time frame, not all at ONCE...because it's dumb to do a ton of mods at once, you never know which ones work and which ones didnt do a damn thing. But I'd prefer to do all of the PITA mods in the same time frame:shrug:
the harmonic dampener is the only thing designed to absorb vibration. As long as the Flywheel and pulley are balanced by themselves, you should have no problems. The crank, fly, and pulley are balanced separately then assembled, not balanced together. See where I'm going? Save some pounds, go light-weight. Sleepcounter even brought up that it would lessen the stress on the bearings because of the reduced side-loads or some such compared to the heavier flywheel.
Quite right, my apologies for the missinfo.
Whatever happened to a763811 anyway? I miss the arguments. :(
If the flywheel itself is balanced (which it is) that is all you would have to worry about in terms of bottom end balancing.
HotRodMex said:
(good value or cheap crap, only experience can decide). they're at www.specclutch.com . .
there cheap crap, i bought one for my tiburon at kore motorsports like two years ago, and from the begining once it got hot, it slipped, i actually have had to pull over and sit and let it cool off just so it would ingauge, customer service pretty much told me to screw myself, spend the cash, buy a dxd clutch.
Need more engineers for cannon fodder. You Oz guys familiar with the term schadenfreude?
If you understand tolerance stack-up, you'll know that they should be balanced together. I guess it depends whether you're one of those guys for whom "good enough" is good enough.
Torsional crank loads, actually. Rod bearings would be (theoretically, at least) better off. That being said, how often do you read hereabouts about people encountering rod bearing problems. Not often enough IMHO to justify a US$300-400 investment.
You sure you're not an engineer?:D
You mean he wasn't an alias of yours? Well I'll be!
SixSick6 said:
so by balancing, you mean having a shop somehow install it so it is trued? doesnt seem like there is much to balance besides a couple bolts, how could a shop install it different than anyone else?
Dynamic balancing eliminates vibration which can arise out of tolerance stack-up. Why do you balance a turbo when the wheel's been off?
If "good enough" is good enough for you, that's true. Not the way I'd do it, though.
If only there were a decal.....
SleepCounter said:
Need more engineers for cannon fodder. You Oz guys familiar with the term schadenfreude?.
Isn't that a bit like apple strudel?
Last time I had an engine (datsun L20) "built" at a machine shop they balanced the crank and flywheel as one unit. I don't know how it was actually balanced though, I've always thought small surface drillings to drop weight from a particular area but I'm probably way off the money.
SixSick6 said:
so how is the flywheel itself balanced?
Holes drilled (usually on the outside diameter alongside the starter ring gear) on the heavy side.
Trouble is, it may not register on your crank the way it did on the balancing machine at the factory. Probably won't be that far off, but when the weight is that far from the crank centerline, it doesn't take much.
Same reason you match mark your pressure plate when you take it off your flywheel or match mark your flywheel when you take it off your crank. So that it can get back on the way it was.
You DO match mark your pressure plate when you take it off, don't you??:rolleyes:
1 - 20 of 58 Posts
Status
