The door handle on the passenger side doesn't work. When you pull it, nothing. No tension, no resistance, nothing.
I am taking off the panel today because Im connecting a new mirror on the passenger side, so I'm wondering if any of you have fixed this problem and what I should look out for.
Thanks in advance.
If it has no tension or pull then something has come disconnected. Once you get the panel off you will see the handle is connected to a metal rod it may have just popped out or the handle is broken. It could be lots of things. It should be fairly straightforward when you get the panel off.
Thanks for the info.
Checked your car in that sig link. That's a really nice machine you've built up there. Clean inside and out.
