Discussion Starter #1 (Edited by Moderator)
Picture "How To" Guide for Headlight Sanding
_.:: Photos taken by Rokcrler
_.:: Photos & guide organized, cleaned up, and effects added by rhumen
1. Look at your nasty, cloudy headlights... blech :V
Discussion Starter #3 (Edited by Moderator)
3. Remove the clips and the front clear cover to the lights.
4. Drop the covers into a bucket of water and OxiClean to remove fog from inside and clean the plastic.
5. Sand the headlights down to a powdery white with a medium medium grit (800-1000 grain) sandpaper, then again with a HIGH grit (1200-1500 grain) sandpaper. Sand everywhere you see the nasty oxidation.
Discussion Starter #4 (Edited by Moderator)
6. Drop the covers in another bucket of water and OxiClean to further remove grime that was trapped and is now released.
7. Dry the covers off and apply coats of clear spray paint evenly over the cover.
NOTE ~~> you can apply as many clearcoats as you desire, but be sure to make them LIGHT and EVEN coats of paint!
