I replaced the o2 sensors 2 weeks ago i was geting the code 24, so i desided to replace both while i was doing it, i replaced them with 4 wire denso universal ones. but now i get 2 codes 23 and 15. so i do not know why i am getting these codes any suggestions would be greatly appreciated i want to try to get these fixed asap
the car is stock 93 ls v6 and stock intake with k&n filter
i have serched around and found out what causes the error but i want to know how to fix it thanks again
Ryan
Discussion Starter #2
now there is a strong gas smell when i drive please help karma for for every can help thanks
for the codes i have no clue, but for the smell of fuel, when you move your car next time check to see if your leaking any from the lines or the tank.
Reactions: Voller
My guess: it is not the O2 sensors. Something else is causing problems, dumping unburned fuel in the exhaust, and confusing your O2 sensors.
Do you notice any misfire? When did you last check the basics, like spark plugs and wires?
Discussion Starter #6
i have been checking that stuff when i can but thank you very much karma for you guys
yeah i have reset the ecu thanks though
