hey guys,
im spraying my inside trims or whatever its called and i just cant take off that part with windows switches on the drivers side doors ....
if anyone ever did that before please let me know ... im stuck here ... thanks!
If you are spraying the windows all around...you didn'thave to open up the whole assembly. Use some silicon spray all around. I'm not good with electronics hopefully someone will answer your real question...but for future reference I would spray all around the window seals, it works and never had problems
MarnSue said:
hey guys,
Ohh yeah.. that was tricky... If you take the panel off, flip it upside down so that you can see the underside of teh switch panel. Look inside there, by where you would clip in the wire harneses, you''ll see some screws that you have to undo. They're small and it's very cramped in there so you'll have to use a small screwdriver. When those scres come off, the switch panel will come right off.
Discussion Starter #4
ok well i am going to try that right now ... i had already put back on the panel around gauges and the one around the hand brake ... thanks once again!
