1 - 16 of 16 Posts
WHICH PLUGS Ok i know that this question gets asked alot but i can't see a clear choice on any forums i have read, so HELP!!! Is it NGK, Bosch, Denso which one, better yet everone post to which plugs you have choosen help :cool:
NGK all the way..
Josh
Bosch Platinum 6. About $5.99 a piece, but they're are worth it. I doubt I'll be using anything else unless convined otherwise.
Bosch Platinums are some of the most overrated plugs ever designed. They are more a gimic than anything. With NGK's they are more specifially design for a Probe....as long as you make sure to get the correct part number. NGK's arent as expensive as the Bosch's are either IIRC.
Josh
Now which kinds
Just the basic NGK or the iridium i have old NGK's
Bosch Platinums (regular ones) or NGKs are great. I prefer the plats because they are stocked at my local AutoZone, and are cheaper than NGKs.
I have run both the Bosch Plats and the NGK standard plugs. There is no discernable difference in performance between them.
Just get whatever's cheep. Plugs arn't going to make a difference in performance unless the ones that are in you car are old and not functioning properly.
i just changed mine a couple days ago...... i had ngks in before and wanted to see the difference so i purchased some bosch plat +4's..... so far so good... idle is a bit better and ive seen some improvement on acceleration and gas milage....
i also have a question......... i had some oil in pistons 1 & 3 i believe........ worn piston rings?
Oil in the cylinders (beneath the spark plugs) or oil in the spark plug well? The latter is most common on our cars, and represents a leaking valve cover gasket.
Leaky piston rings would result in oil in the cylinder and oil burning in the exhaust.
yea putting in new spark plugs isnt going to make any noticeable difference unless your car really needs a tune up .But if you are looking for better performance ,ngk spark plugs and spark plug wires would make a slight difference.NGK spark plugs are like 10-12 bucks a piece,so dont waste your money unless you are gonna go all the way and do ngk plugs,wires and msd ignition.
NGK spark plugs are around 2 dollars a piece
1 - 16 of 16 Posts
