Here the thing, every time I'm sitting still and I turn left or right the steering pops and then when I start to drive it pulls intill I stop turn it again and pops again. I'm starting to think it's the CV Joints because it didn't start this till after I did my springs. I think I might have messed up my CV Joint doing that project. :shrug:
You probably forgot to put the strut mount bearings back on between the upper spring perch and the strut mount. It just looks like a black/grey washer but it allows the spring to rotate when you turn the wheel. This will prevent the spring from turning smoothly and it will bind until enough force builds up and it pops into place, resulting in the pull until you turn back the other way and it pops back. You can find some here if you threw them out.
KYB Front Strut Mount Bearing - SM5129
