when i excellerate in 1st gear i hear it a lil in second alot n third it starts to go away its a popping it sounds like up front i have a 95 mx6 ls v6 5 speed just changed the brake calipers everything else is perf flid lvls n everything what could it be'?
I'm experience this same problem, but mine only started today. i was checking out my spark plugs, and the a few of the wells had about an inch of oil in them around the plugs and coating the leads. i cleaned the leads and sopped out the oil as good as i could, but when i went for a quick drive, my car started popping. i think it was only under slight load, under heavier acceleration, eg. 4-5000, it sounded fine. but backing off and slight load was popping.
Any help would be great.
Luke
mx6
Have you ever had a problem with your distributor? If not check
that ****er, check the wattage to it's cottage, I've smoked two
of those ****s already! Costly, but I guess it's common. How long
has it been since you've tuned it ? Change the oil, air, fuel filter,
battery all that dumb stuff. Always be aware of your oil level,
too much=****ed, too little=****ed. Definitely take it to someone
you trust(no dealer they will **** you!)
mine was lame when the timing decided to start going
it was the tensioner and even when the belt goes no worries non interference engines rule
