i looked at previous posts regarding a manual tranny V6 MX6 coming out of gear and was curious to why this happens? Mine only pops out when travelling at about 75 mph ... any less and it doesn't come out. I still have to check the fluid level of the tranny but what is the main cause of this problem? Besides this problem, the car shifts very smoothly and the clutch works A1.
craig
From what ive learned, 5th gear is set higher than all the other gears in the tranny, so when your oil gets low, it gets little gear oil, and causes it to pop outta gear <- this is bad, fill your gear oil. When you do a rebuild, make sure you get a good warranty.
Exactly what he said low fluid. Top it off and check for leaks make sure there's not cracks. I was leaking fluid and didn't know where it was coming from mine started to pop out of fifth as well. And with my busy schedule I waited to long to fix it. I ended up burning up my 4th and 5th gear.
