i bought myself a 1993 mazda mx6 ls mystere (2.5).. i noticed since driving it thats its not as fast as it should be. when i accelarate quickly. theres a noise coming from the motor.. sounds like air spraying out somewhere.. I've had a couple guys say its a leak in the manifold maybe.. I just wanted to know wat you guys think.. I could try posting a video so you can hear it. and just today i barely beat a mitsubishi eclipse. (140hp version) and the guy driving it barely knows how to drive 5spd.. And everytime my fans go on my engine light goes on too
check for any codes on the CEL and as far as the air/vacuum leak, how is ur idle ? if it's rough/low it could point to a leak.
my idle is actually higher than normal it usually idles around 1,500+ rpm and sometimes drops down under 900 or lower rpm and back up.. seems like its about to stall when that happens
