1 - 13 of 13 Posts
I'm not sure if the GT's have this but my 89 LX atx has a power switch I guess to give you a little extra power boost. I've read the manual, and that's what it says. But what I want to know is what is the real differance other than the fact that when I have it set to power and not "Econ" it sucks gas like no other. I looked through other threads but no one has asked about this so I figured that I might as well bring it up. Does it add any horse power when you have it on? Any info would be apprecated.
Jason (Pyro)
89 LX stock (soon to be modified)
dear pyro,
continue to use the POWER button and you will screw the tranny like I did and pay a good 1,400. Just get a manual for some power. i wouldn't advice you to.
You just simply stretch the gear ratios it is another way of overdrive...i used it for 6 months like a speedster and it i had bad problems...rebuilt tranny.
anthony
Ya i know the power button u are talking about And i noticed that it does make alot of difference When i drove it on economy it was ok but when i switched to power Yes it did go faster Im think its just the RPM When u drive on economy it just brings down your RPS and when on power it has them higher
The power button will NOT hurt the tranny. If anything it'll help it because the engine tends to lug a bit in economy mode placing additional strain on the torque converter. integrale4wd, your transmission must've had an underlying problem to begin with or it was coincidence.
AT Econ/Power switch
toyota has them too. In japan anyway....
Anyway the switch would be located next to the cruise switch if you had an ATX.
misnomer
No offense to integrale 4wd, but I wanna clear up a misconception...
quote:
"You just simply stretch the gear ratios it is another way of overdrive"
There are sooooo many people who have the idea that overdrive is something that makes a car have more power, accelerate harder, etc. There are songs about cars where the guy sings "I put my foot down and went to overdrive" or some such thing, and you always hear people talking about how they got into overdrive to pass some guy or whatever.
But....
Overdrive is NOT for making power or accelerating! Overdrive basically changes your final gear ratio for low RPM, high gas mileage cruising on the highway. Many old cars had manual transmissions w/ overdrive on the 2 top gears. So maybe it was a 4 speed, + you had overdrive on 3rd and 4th, so effectively it was a 6 speed trans. You'd use overdrive, like I said, for cruising.
I think as automatic transmissions got so popular in the last few decades people have just not had experience with O/D, or they hear the word and it sounds like something for making power and they assume that is the case.
When these mistaken people say "overdrive" what they REALLY mean is "the passing gear" or "downshifting".
However lots of automatics still have overdrive...there will be "D" and D with a circle around it or "D (o/d)" The D with the box around it on you shift gate is overdrive...it's for gas mileage gettin'.
I don't mean any offense to people who've made this mistake, I just cringe when I hear the word "overdrive" being used exactly opposite of how it should be. So let's all say "passing gear" from now on :)
And as for that "power switch". I had one on my old LX. It should have been called the "hill switch" or "mountain switch" because that's really what its good for...full throttle acceleration in the power mode and non-power mode is that same...part throttle acceleration is better though in "power" because it holds the lower gears longer. (I guess you guys already went over that above). Ok enough from me.
[Edited by antiSUV on 12-02-2000 at 03:18 AM]
1 - 13 of 13 Posts
