Anyone ever had a ps fluid leak?.... i just discovered i had this problem because i guess i can hear the pump which makes a really annoying sound... i just wanna know if this is a common problem...
Common Indeed
Its a common problem with almost any older car. There are numerous resons for what causes PS system failure. In our cars it usually caused by a loose banjo bolt and worn copper washers. Although there are many points onthe system where a leak is probable. Get it fixed or if you're in need of bulking up your arm strength unplug the switch wire and let it be.
and what? hope you dont have to make any emergency manuvers anytime soon?
top up your fluid, locate the leak and fix it.
