Greetings!
I tried a search, couldn't find much detail, so here goes...
My '91 MX-6 GT driver's power window only goes down to about 6" left (exposed) and then stops. Upon further investigation, I realised that the little button in the track (put new one in my '89 GT, R.I.P.) is not holding the window in tight. I remember when I replaced the other one, there was an Allen key slot in the back screw that holds the bastard in there. Also, the rubber track that the window slides against is a bit chewed with some pieces gone (not adding to the smooth slide-action!)
Questions: How do you access this Allen key? Guy at the dealer said grab the nice, new-looking black side that faces the outside with some needle-nosers and tighten it that way! Not fond of scratching the s*** out of something I just paid $18.00 CDN for! ALSO: Is it possible to replace that rubber piece at the rear-end of the window? If so, how?
All comments appreciated!
warrlock2000
warrlock2000
