Hey, last night i installed my reverse indeglo gauges but im having a problem with the rpm gauge n my car temp gauge.
when i put the needle back on for the rpm gauge i put it at zero and the car temp gauge i put it all the way to the left. when i installed the gauges into the car automaticly the rpm gauge read 2k on it AND the car not even started!! same with the car temp it read hot already . when i turn on my car. both needles are way off.. how do i fix it!! HELP ME!!!!!
Discussion Starter · #2 ·
TTT...help me ... its driving me crazy
oh! you have an auto
well it looks like you put the needles off by quite a bit. to fix it, turn on the car, wail till it gets into normal operating temp. then reinstall the temp needle where it would be at center, and reinstall the rpm gauge were its idling at rougly 650rpm assuming it did not have any idle problem before. take it for a spin and make sure your speedometer is fine, it should hit 20kph when your rpm is around 3k.
thanks a lot man.. ill try that out tomorrow when i get a chance too.
