does anyone know where I can get directions on removing rear tail lights for an 89 mx6 and a 93 probe ?
First off, the lounge is for non-car related threads.
As far as answering your question, check your owners manual, it may be there under bulb replacement or maybe in maintenance. If you can't find anything there, give the search function (upper right coner of your screen) and if you still cant find anything, browse through the first and second gen tech sections, the question may have been answered before.
-Bryce
2 ways to removing every part...the easy way (via torches/sledgehammers) or the hard way..
i can help you do it the wrong way if you like :)
easy easy
all you need to do is look for the small bolts that hold in the tail lights(89 mx6) the ones on the side that has the turning signals and so on are real easy but the one part in the middle is a b**ch.
Dont forget to take off the screws that are underneath the liscense plate, and the two bolts that require deep socket. ok now you have to pinch the two black bastard clips on the side and PULL.Thats it.
