anyone know about Prove v6 radiator fans? the passenger side fan turns on when its hot but the driver side never goes on.
As I can see that the 2 fans are designed differently but can someone explain this?
cooling fluid is full but temperature is always in the middle of the gauge.
ones for the Aircon, turn it on (the AC) and watch the magic.
sounds like you have a problem then, have you checked for codes? if theres no relay fan code check the fans connected and apply 12v manually to see it operates.
as i recall the passenger fan is for the ac...it should only come on to support the main cooling fan (drivers side=disty side of motor)...check the fan relays
edit: unless its a rhd car?
