probinator chip trouble code?
632 Views 5 Replies 4 Participants Last post by  mx6 z28
Just curious if anyone knows whether or not after installing a probinator chip if you can still pull trouble codes or not?
Thanks!
DREW.
reason why i ask is my engine light was coming on b4 i installed the chip and not after???
I can pull codes just fine
What was the code that it was showing before the chip?
Yes you will be able to, and most likely the power cycling of the ECU cleared your code. But to make sure in your case, I would very that the diagnostic light comes on when you check it.
Thank-you for all your responses, and I will deff get to those code checks soon.
DREW.
