Ez All,
Need major help, I popped into a store for about 10 mins to pick up some gear, then got back to the car, and turned the key, however there was nothing there at all. The engine was fully warm and the battery was fine.
It was weird, there was no noise what so ever when i turned the key. All the igniotn light's batter light etc were ready, but nothing when I tried to crank up the engine. The engine's in excellent form, so i'm baffled by this.
All help advice idea;s appreciated peeps.
If its an Auto make sure you have it in "P" or "N". I had the same problem in my previous car. Move the from "P" to "N" and back then try.
If that doesn't work your start moster could be dead or the relay is dead. Also this happened to me. The power lead to the relay for the starter came off.
BTW this was in a 2nd gen 626. Don't know if it helps.
First thing you should do, is clean the terminals and battery cable clamps off real good. Then retighten and try it again. Have you been able to get it started? Do you have a mtx or atx? If mtx, can you pop start it?
