The car attempts to start and will start but won't stay running. THen if you try it again it won't turn over. It has new everything. Anything else?
When you turn the key do you hear a clicking noise? have you tryed to jump it? do you have any codes on the dash when you turn the key? do you have power to your dash/lights ect... you gotta help us out more info if you want us to give answers dude
Edit... iam thinking its your Alternator thats on the last crank....if you have juice in the batt your car will start, but if the alt is not giveing it a charge it then it will die and not start cause there is no juice in the batt due to it ... get a load tester and test the alt and i bet its your problem
Next time it acts up and won't start on the second attempt, check for spark.
What do you mean by "new everything" and how recently were these parts installed before your problem arose?
