1 - 8 of 8 Posts
My handbrak/brake warning light in the cluster always lights.
I've tried to remove the cable located near the handbrake (the one that senses if the handbrake is in use) .. no diffrence..
My brakes works fine and i'm now low on brake-fluid
Any suggestions?
You answered your own question. If your fluid is low the light will light up. If the system is open (IE has a leak) the light will light. The pressure in the master cylinder is wrong it will light. You have a brake problem, now you need to find it.
~Chris
i mean i'm not low on breakfluid =)
no leaks either and the breaks works fine
where are the sensors for the lamp? i know there is a red wire next to the handbrake, any more? brakefluid-pressure sensor?
damn , seems to be a leak somewhere. But i filled it up with new break-fluid today and we'll see what happends, the warninglight stopped anyway when i refilled=)
no air-bubles in the break-lines anyway..
1 - 8 of 8 Posts
