1 - 1 of 1 Posts
Proform Shift light, Adjustable from 3k rpm to 12k rpm.
It has a dial on the back of it for easy adjusting. It can be mounted stationary or temp. Currently its set up to be temp mounted on the windshield/gauge cluster or dash. Ill include the mounting bracket to mount it stationary.
Super easy to install, preset for the V6 KL motor, 3 wires, Positive, Ground and Signal. Attach the signal wire to the green wire on your disty and your set.
It can be used on a 4-8cyl as well, but will require some wires to be moved around inside the shift light.
$28.00 Shipped.
1 - 1 of 1 Posts
