M
Guest
How do you attach the side skirts and the back bumper pieces? Do you have to drill or what? Anyone do it there self?
installing
You can either rivet the pieces in. The front has to be screwed in to certain places. I used a brace for the top section and used 4 brackets for the lower section. The sides are easy to install, all you do is use screws both in the middle where the door sill is and front and back. The rear has to be riveted in since you have to do front and back section, then you have to use a filler to cover the riveted areas.
