1 - 1 of 1 Posts
Ok so my tps is out of wack, so i cant get my idle right. I just put in a new distributor so i have to set my timing. Now my car normaly idles at 1000 rpms When i jump the terminals and start the car it takes the idle down to 650. So right there i can get the timing at 10 tdc. but when it is idleing normaly the timing is at about 18 tdc at 1000 rpms. Is that normal?? does the timing change at higher rpms. Would i get a differant timing reading at higher rpms??
Thanks for answering the noob question
steelersfan.
1 - 1 of 1 Posts
