S
Guest
Hey Guys, here's my first post on this board. I'm lookin at a 94 MX-6 LS, it's pretty badass to me. Black, stick,leather, yada yada. I've got a question about the stereo for ya. It's got the 6 speaker system with the tweets up in the dash, are the crossover's built in to the car or the stock headunit? i know i'll be putting in a new headunit and i'm wondering if i need an adapter to run the tweets with an aftermarket hu. Also, will i need any other adapters to bypass any amps or anything? Thanks guys.
The stock tweets just pop out of the dash and have a short wire with a connetor on the end.There is no crossover in the deck and the amp is part of the deck-the tweet just has a small capacitor to filter the lows.Buy a Mazda wiring adapter to put on your new decks wires and just plug it into the factory harness.Some of the new decks will keep the power antenna down when playing cds and only come up on tuner mode-something to look for!
[Edited by SLINK on 05-20-2001 at 12:44 AM]
Yep, exactly as Slider said. Also when changing the deck, to an aftermarket one, you may need to rewire the power antenna configuration. You can buy an adapter for that.
