I didn't mean to suck air in the radiator.... me is silly, I meant push air out... I never read over my post. DUH!
If you have a blown head gasket you can experience different things going wrong with the car, and depending on where the actual break in the gasket and how big. Different things are required to check for depending on where the break is (and you don't know this yet).
IE - Water in the oil etc.
Sometimes you will find that the engine instead of pushing air out the exhaust the air will go into the water in the engine and hence come out the radiator.
To test for blow by, just start your car (in neutral or course
) Then take off the oil filler cap.... blow by is when you have loose seals on the pistons rings or the valves aren't closing properly... or both. This way the compressed air in the cylinders is slipping past the piston rings and out the top rather than out the exhaust. Now, being 13years old, your car probably will have some blow by. There is no real amount where you say... I need to fix this now. But in my opinion, if it is starting to smoke, and you can't find any other reason, and you have oil being thrown out the tappet cover... then you may know why
Hope this helps.
