E1, E0 are non-turbo. They'll fit the same but according to Mazda aren't the same, hence twice the pricetag.
Nice...E1, E0 are non-turbo. They'll fit the same but according to Mazda aren't the same, hence twice the pricetag.
The turbo ones supposedly have a high sodium content.They work fine apparently, what is the real difference between them? Ceramic coating?
Gah,The turbo ones supposedly have a high sodium content.
He never said they had sodium in the middle nor sodium filled, just high sodium content. Are you a metallurgist? Have you taken the time to analyze the metal and it's chemical properties?Gah,
They don't have sodium in the middle.
They aren't sodium filled.
shame on you for perpetuating that myth.
IF *anything*... the exhaust valves on the GT *are* different because they have been heat treated, and are harder than the non-turbo exhaust valves.
Which makes some sense as the GT exhaust temperatures are higher than the non-turbo exhaust valves, so you'd want valves which maintain their strength better at higher temperatures.
everyone who has cut the exhaust valves apart has noted that it was significantly more difficult (ie. they when through more cutting wheels) than the intake valves, or the exhaust valves of the non-turbo.
Keep those exhaust temperatures down, and it simply doesn't matter.
But there is no sodium in those valves.
Well first off, if you're going to use BiG wErdS, lrn2spell catastrophic. As for running 14psi, my head had two E0 valves in it, #1 and #4. I ran 15psi on a tbird for quite a while with no issues.Well if anyone can answer this:
Will running 14psi lead to catostropohic (ThAts RighT, BiG wErdS) failure eventually on E0 type valves?
I would like to know if anyone has experience of problems, so I can figure out if I need to save up money now and replace them before I will need to replace alot mo'.
Freaking awesome, thats all I needed to hear. LOL was waiting for someone to point out my horrible mispell, after I noticed it...I was to lazy to fix it, you r winnar!Well first off, if you're going to use BiG wErdS, lrn2spell catastrophic. As for running 14psi, my head had two E0 valves in it, #1 and #4. I ran 15psi on a tbird for quite a while with no issues.![]()
I'm glad someone actually READ what I wrote:tup:He never said they had sodium in the middle nor sodium filled, just high sodium content. Are you a metallurgist? Have you taken the time to analyze the metal and it's chemical properties?
Shame on you for failing to read what I wrote. I have to give you an F- today in your Internet Reading class.Gah,
Try again, and come back when you've read it all. I'll re-grade you then.
Dictionary said:sup·pos·ed·ly [ sə pṓzədlee ]
adverb
Definition:
as people believe: as some people believe, or as people were led to believe
He was supposedly going to pick us up after work.
a supposedly instant remedy
Read up again. And try and comprehend it correctly this time, as everyone else would read it. Not how you want to twist it to your own views and interpretations.I'll be happy to retract my rejection of defilers statement, as soon as defiler retracts his suggestion that there is sodium in the valves, something you ought not do claim, unless proof can be provided.
Going on a long rant about absolutely nothing (Other than your misnterpretation) is more than silly....Suggesting that there is sodium in the valves is just plain silly.
But I thought you just said you were not, in fact, a metallurgist. So how would you have any idea on the applications of sodium in metals?Am I a metallurgist, no. However, there is no practical reason for there to be sodium in the valves.
