i have a small hole leak in the lower front of my radiator a rock probally hit it its less than 2 years old any way iam going to buy the part and do it my self my has any body else had this problem? is it a fairly easy job any help advise tips would be greatly appreciated thanks
pinhole leak in the rad
If it's been 2 years, the leak must not be bad. But any leak within the cooling system should be corrected. While R & R of the rad is a relatively simple task, I'd recommend having the rad repaired by a shop. If it were an older car, then it might be more beneficial to replace the rad, but it'd cost more.
Once repaired, an easy preventative solution may be to install a piece of screen mesh in between the rad and lower bumper air intake grille.
Rad
The choice is yours, but I'd have it repaired.......being as new as it is .
