Real quick tire size question
929 Views 4 Replies 4 Participants Last post by  redbond1
I have hyundai tiburon gt rims and my tires are just about shot. The rims are 17x7inches and have the stock 215/45/r17 Michelin Pilot tires. I found a good deal on some new pilots but they are 235/50/r17, will these fit or are they too large? Also, if they wont fit are there any other sizes that would fit the rim or just the stock 215/45/r17? Sorry if this is a noobish question I don't really know my tires too well. Thanks in advance.
those tyres are way to big, even if they did fit your speedo would be 4 mph off. I use 215/45R17's they are the right size
If you search there is a tire size calculator on here or also you can use ebay but the rule of thumb I always go by is for every 10 you change the first you change the middle on by 5
eg... 215/45/17 and 225/40/17 should have a very similar diameter about 1.5% off as well as 205/50/17. This is not exact on everything but if you are looking for deals and run across something this is what I always go by pretty close but not exact. Better if you use a calculator and figure out exactly what sizes work
Tire Calculator and Comparator is a good calculator
Tire size calculator this is the one i used
I run 225/45/17's the speedo is out 5 km/h at 50 and 10km/h at 100 km/h but 225's are as wide as I would want to go on a 17x7 rim... VERY close to rubbing the strut.
