Hey all, recently had to change to right side O2 sensor (you know, the tough one). Add to that I recently installed the phenolic spacers.......ever since my gas mileage is the shits....? whats up with that? any ideas?
Try this
First do you have any modifications to your car? Second, did you reset the computer by unplugging the battery?
the only mods are the phenolic spacers (under the intake) and I don't use the stock airbox.......
thanks
MIke
pull the codes, maybe the other O2, or maybe the cat. is burned up. fuel pump, fuel filter, bad fuel injectors.
try to run some fuel injector cleaner. later
