SO resently my car has started having the following problems. I get a fast blick on the rear turn signal when the brake is depressed, but it is fine if the break isn't depressed. Using the left run signal takes you out of crouse control just like if you were to tap the breaks. Finally the check engine light comes on every once in awhile for about 10 seconds. It comes on maybe every 60-70 miles, but doesn't stay on for more then just those few seconds.
I assume I have some funky wriring short or something and was curious if anyone had any ideas.
