I just wanted to post on here because the threads I've found were not very specific. I removed my side marker lights for the rear tonight and changed the bulb. You have to pry from the side (not from the top or bottom) the clips that hold it in are facing rear and frontward. When I have done the fronts, I removed the bulb from behind by taking off the fender walls and reaching under. I'm not sure if you can take them off from the outside but I assume they are the same as the rears. The bulbs are 194s. This applies to 2G MX6.
I have a 1996 Mx6 M-edition by the way.
