what does it mean when you press on the back and both sides(susp) making klicking noises? is it bad? or im just paranoid?
thanx
Guest
Probably strut mounts or some bushing going bad. Relatively cheap fix but kind of a pain if you're doing it yourself. Also, try to listen to where exactly the noise is coming from. It might just be something loose in your trunk.
