1 - 17 of 17 Posts
FAQ needs help. We have the content, and the body of knowledge... but we don't have any effective way to present it to the user - either new or vet.
Instead of patching it all together from the fragmented bits that we have - I'd like to rebuild a FAQ altogether, in easily used and printed PDF format. (please submit to me in an editable format, however. We will create the pdf's and watermark them appropriately)
I have no problem referring to and including information from some of the excellent write ups out there (such as the Leska write ups) BUT - with pic links long since dead, the write ups often lead nowhere. If you have these saved anywhere, please forward them along. Thank you to the several members who have already forwarded along what they had.
Please submit any pics and the associated write up (if its not yours) to me, and we can start rebuilding the FAQ to properly represent the body of information this site contains.
The functioning write ups with pics that we do have - if you are the thread originator, I'll be contacting you with any edits, additions i might need, as well as placing them into pdf formats.
I'll be fielding as many of these as i can, myself, but all help is appreciated, and indeed necessary for us to have a usable FAQ within a reasonable time period. Please note, MOST of the categories below already have a write up somewhere. I'm just using this as a checklist of sorts, and making sure we use the most updated and complete information, and most importantly, have actual pics, that we can attach and host HERE so we do not rely on the comings and goings of external hosts.
engine/ related:
- Intake Manifold R&R
- Valve Cover Gasket R&R
- Motor mount R&R
inserts R&R
filling a mount
- Phenolic Spacer Install
- Transmission R&R
- Power Steering Pump R&R
- KLZE swap
- Axle/ CV joint Replacement
- Distributor R&R
HEI coil install
- Timing belt
Water Pump
Accessory belts
- Alternator R&R
- Thermostat R&R
Radiator R&R
- Adjusting the TPS
- IAT mod for the atx
Performance:
-CAI install (we have several options already, but the more ideas the merrier.)
- BBK ideas and installs
- performance headers
- Cat back installs
- Custom exhaust ideas
- suspension upgrades
- sway bar upgrades
- short throw shifter how to
- IM gutting for f/i
- VRIS controllers
- underdrive pulleys
- performance clutch/flywheel (goes along with Transmission R&R)
- 929/millennia master cylinder upgrade
- Weight Redux
- SS brakeline install
- SS clutch line
- Battery Relocation (performance? heh)
Appearance:
- indiglo installs
- jspec headlamps how to (with wiring)
- espec headlamps how to
- angel eyes how to
- HID installs and retrofits to any of the above
- Spoiler/Wing how to
- clear sidemarkers R&R
- Valve cover painting, powdercoating or polishing
- Intake manifold painting, powdercoating or polishing
- detailed body kit installs (some need more work than others)
- Custom work (fender flaring, fiberglassing, hood scoops, fender scoops, splitters, adaptation from other cars, flushing, frenching, interior fabrics, etc etc etc...
- Detailing
Wax and compound
Clay bar
Leather treatment (Graham's write up is the gold standard so far)
ICE:
- system installs
- headunits
- subwoofer ideas
- Amp wiring
- carputers
- Custom work (enclosures, midbass installs, amp racks, FG work, automobile integration etc etc)
- navigation systems
- Megasquirt (lots of possibilities here - pics appreciated)
- lighting (led, neon, etc)
General Maintenance:
- oil change (we were all once newbs, right?)
- air filter change
- pcv change
- brake bleeding
- Tranny fluid change/flush (atx and mtx)
- kerosene/seafoam flush
- throttle body/IM cleaning (installed, via seafoam, or removed and scrubbed)
- Brake pads, front and/or rear R&R
- Brake discs
- Rear calipers (rebuild, replace, or upgrade via protege 5)
- Master and Slave cylinders R&R
- catalytic converter R&R
- Fuel Filter R&R
- Spark Plugs
Spark plug wires
Distributor Cap and Rotor
- Headlight bulbs R&R
- Turn Signal Bulbs R&R
- Brake/reverse light bulbs R&R
- rear trunk struts R&R
- set idle
- MALF codes/ paper clip trick
- Specs and capacities
Chassis:
- Rear endlinks R&R
Front endlinks R&R
- Heim Joint adjustable upgrades to either of the above
- Rear swaybar upgrade
- Lower Control Arm R&R
Ball joint R&R
- Tie Rod ends
- Crossmember(s) R&R
- Trailing arms R&R
poly bushing upgrade
Feel free to make any other suggestions here but lets not go crazy with really , overly specific write ups - thats what the forums are used to discuss.
small print:
Please be aware that as this is a public forum, once you submit your work, it will be subject to web crawls, cached pages, etc. Intellectual property laws protect you against someone else taking credit for, or making a profit off of your write up (for instance, ebay repair CD's, etc) however they do not protect your ability to control the information once you voluntarily submit it... Once submitted, we cannot guarantee it will not be externally linked to, distributed, or otherwise used. We (mx6.com) will ensure, to the extent that we can, that credit is given where credit is due, and will attach a digital watermark to each document created. At no time will mx6.com be required to delete a write up, once submitted, unless it is found that the work, in part or in full has been used improperly, and is not owned/used with permission by the original submitter. By submitting these write ups, you agree that this information is intended for public distribution, and will be kept freely available to all users of this, and other sites who choose to use it.
Wow! Sounds like a seriously major effort! Sadly, I don't think I've got all that much to offer other than encouragement.
Discussion Starter #4
yes.. it pays 0.00 per hour :D :D :D
i wish it paid by the hour man lol
Will work for rep... :cool:
Seriously tho, if you need anything rewritten, proofed, edited, shortened, spellchecked... whatever... I'm pretty good for any/all of the above, let me know if you need anything...
Discussion Starter #7
wow - excellent. This will go a long way toward what we are trying to accomplish - excellent!
If you give me a Car to rebuild, ill do it for you and picture walk through it.
High & low beam headlamp
9004
9004ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9004XV XtraVision Halogen Upgrade: Up to 20% Brighter
9004CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9004LL Long Life Halogen Upgrade: Lasts two and a half times longer
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: the whitest and brightest Halogen
License plate
168
Back up light
1156
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
194
Glove box
194
Map light
168
194
Dome light
194
DE3175
Step/Courtesy light
158
194
DE3175
Trunk/Cargo area
168
194
Instrument-general
194
A write up on replacing the power steering rack (which is a fun job) would be nice... I'd be more then happy to help with that as I figured out a nifty way to get the rack out without touching the subframe.
Well, my fiancee's sister overheated the engine and blew the head gasket, so you know I'm going to be taking lots and lots of pictures of the head gasket job...
I know EXACTLY what you need....
...and how to do it. I'm a database administrator :) You guys have helped save my mistress so many times it is the least I can do to return the favor. My fiance' says my car is my mistress and her name is Cristine and it HATES her. lol
You need data mining. It would take some doing with site permissions and trust. I'd be willing to submit my creds to you GP. Get in touch and we'll see if we can work out the details. I'd do it for free but need select permissions directly to the backend database and could directly export to any format you would like. Ask admin of site for backup of database, easiest way.
'nix
Might want to include:
1) How to get the air out of the coolant to fix the high idle, pretty common if you have had any sort of coolant related issue.
2) ATX tranny cooler install
3) Valve cover gaskets (especially rear) Nevermind you have that
4) ZE install needs it own FAQ, I recently did a writeup on how to fix the constant fan issue in the 94+ models if you want to add that.
1 - 17 of 17 Posts
