Most likely it is an optional output wire that will only be used if you need to interupt a circuit while the car is started, say like an alarms shock sensor, or if you need another ignition output to run say the 2nd ignition so that the AC and headter work when you remote start the car. If you don't need either of these then you can cut and tape it off as you don't need it.
