Anybody know how to remove these on my 93 LS??
please dont tell me youre gonna put those LED nozzles on?!?!?!
please DO tell me how to get mine out!!
and ok...i'm not putting the led ones in
You need a torch and a thin screwdriver.
they just snap in place when you put them in from the top so you just need to push one of the plastic clips and it will start to pop out then a little pull from the top and shes out.
cheers
POP'EM out!!!
If you have a paint job to do on the hood - go ahead and scratch it with a screw driver from the outside. What I did with mine - I opened the hood, carefully removed hoses from, and I also had to cut a little hole in a black mat that is stuck to the hood to reduce noise, then got a thin screwdriver and a flashlight. You will see 2 clips - just pry one in towards center and "help" it now fron the outside with another screwdriver. Off it goes, right?
Good luck.
Max. :V kia, hyunday, daewoo
oops
thats what I was saying just not as eliquently. just read post and it wasnt clear about doing it from the under side (you wouldnt need a torch as I mentiond if you were doing it from the top.)
cheers max
