I was trying to replace my alternator on my 97 4cyl and realized that the alternator doesn't fit out without crossmember removal (says the haynes manual). I got it out and realized it had nowhere to go. I was looking at it and it looks connected to some rather important suspension stuff. My question is, if I just unbolt the crossmember, is that all that would be involved or will a bunch of other stuff connected to it fall? Thanks in advance!
It's fine to pull it off. I would recommend putting the front of the car on stands though, it will make it MUCH easier for removal and installation.
yes. put the front of the car on jack stands. and it will be okay to take the crossmember off.
I had been driving my car without the cross-member but not alot and not aggressively.
That was maybe a mistake, though. I "assumed" that the cross-member was basically a lateral reinforcement that one could leave off for a short time as long as you didn't test the suspension too much. Maybe that was "stupid".
I do have a thrown rod but thought it unrelated to the cross-member.
What is the specific purpose of the cross-member?
Yeah, I think it's there for a reason. If you're going to before it, wear a helmet. They have a nasty habit of not coming off with the bolts out, only unexpectedly when you hit it with a hammer. I should have taken pictures of the bruise.
