What you will need: Piece of wire that is stripped on both ends.
Instructions for the 2.2L engine:
-Make sure the engine is off and the key is out of the ignition.
-Locate the loose single wire harness near the driver's side strut tower. The wire should be red. This connector is called the self-test input connector (STI).
-Use the piece of wire to connect this STI connector to ground (negative battery terminal works well).
-Turn the key to the "ON" position, but do not start the engine.
-Codes are displayed as flashes of the CEL with pauses between digits. If the code has two digits the flashes for the first digit are slightly longer than for the second digit. If there are multiple codes in the ECA, they are separated by a slightly longer pause. Codes are displayed from lowest number to highest, then repeated.
-After repairing a malfunctioning sensor, you need to clear the ECA's memory. Do this by disconnecting the negative battery cable and holding down the brake pedal for at least five seconds.
THE CODES
1989 ALL
Code Sensor or Description
01 Ignition Pulse
02 Crankshaft Position Sensor (CPS)
03 Cylinder Identification Sensor A
04 Cylinder Identification Sensor B
05 Knock Sensor or Knock Control Unit
08 Vane Airflow Signal (VAFSIG)
09 Engine Coolant Temperature Sensor (ECT)
10 Vane Air Temperature Sensor (VAT)
12 Throttle Position Sensor (TP)
14 Barometric Pressure Sensor (BP)
15 EGO Sensor (EGO)
16 EGR Valve Position Sensor (EVP)
25 Pressure Regulator Control
26 Canister Purge Solenoid (CANP)
28 EGR Control Solenoid Valve (EGRC)
29 EGR Vent Solenoid Vavle (EGRV)
34 Idle Speed Control Solenoid Valve (ISC)
42 Turbocharger Boost Control Solenoid Valve (BOOST)
but i don't think you guys got the CEL. so ther must be somthing elce to it.. some one will know..
