1 - 20 of 33 Posts
try pt search for member xtomx, he's got some on his cd, his r better than mine.
The Full Dong
travis williams has some pics of his setup on PT.
Yes, that is with an oil filter relocation kit....which we have available. :)
BLock-off plate, OPSU relocation bushing, all lines, aqp fittings, ect.
Currently I saw 4# withthe stock crank.....looking into smaller S/c Pullies or the overdrive crank pulley from adlorin.
But with 4# it is bolt on, no fuel req. and no other upgrades.
Just a slight Kick in the pants. :)
Not even an upgraded fuel pump is needed? I know 4lbs isn't a lot but I'd figure you would still need it. I definatly would want to keep the stock charger pulley as I wouldn't want to loose the clutched functionality of it, so a bigger crank pulley would be the way I'd have to go. I'm curious if you've got pricing down yet (or at least a ballpark estimate) for everything but the blower?
we're trying to keep the price of everything under/around $1000.
We've had positive response to this pricing.
eBay S/C's go for $100-300, take that off the Total Kit Price.:angel:
i'd suggest a fmu and a fuel pump even on 2.5psi. if u don't get a fmu u'd be able to use a afpr and stay at a higher fuel press. i've got a 12:1 fmu that i'll be selling for $45 shipped.
i'm pretty sure u don't, that looks like the notorious tkt sc.
So under/around $1000 with the blower I take it from that statement? If so....wow that's amazing pricing!
1 - 20 of 33 Posts
