So whch of the million bolts lets the intake turbo housing rotate into the desired location? is it the 6 bolts on the turbo housing, or is it the 4 bolts in the middle of the turbo and do u have to remove the bolts to rotate the housing or can u just loosen them also is there any seals i have to worry about messing up? i need help asap trying to do this tonight!!! thanks
to rotate the compressor side cover part, there are like 6 bolts that hold brackets, 2 bolts per bracket, and u have to just loosen them, and then the compressor side is easily spun to whatever desired angle
no seals
well let me c if i understand u the bolts that r on the exhaust side the ones farthest on the left side of the turbo? just trying to make sure
its the compressor side of the turbo, but the bolts face the exhaust side. sometimes the bolts will hit something and you'll need to take them out one at a time and get them past the spot where they hit and put em back in.
Highly recommend to dont take more than 1 bolt out at a time. You dont want the housing to move and damage your compressor.
Dont take them out at all if at all possible, just break them loose, spin it, and tighten them back up.
On mine i didnt have to take any bolts out all the way, just loosened them up and it turned without a problem.
