My new ZE runs well, but the exhaust is very sooty and smells of gas. It is consuming fuel at an alarming rate, but I don't yet have enough miles to have a
handle on that. It is bad enough that I'm worried about the fuel washing the upper cylinders and leading to ring and bore wear.
I'm going to check the thermostat, but the temp guage is reading normal. I wonder if the coolant temp sender on the ZE is sending a different signal that my stock ECU is reacting to by adding fuel. I have not read that I should use the original DE sender, can someone confirm?
Any other things to check? There is no fuel leak, I know it is going through the engine.
Thanks.
Thanks.
