1 - 15 of 15 Posts
This is a web page that Frank (dutch showed myself).
Key points are 165 hp, FE ZE and 5 spd 4WD.....LSD
http://www.auto.vl.ru/catalog/mazda...43?PHPSESSID=0471254139304ac84ea6e4be932bc750
Now here is a translation. Its from a online translation site :freak:
Key parameters
Type of body Wagon
Drive FULL 4WD
Transmission 5 speed manual
Volume of the engine, kub.sm 1998
Mark of body E-GVER-C9D
The price of the new machine in Tokyo, one thousand yens 2395 (~ $19900)
Specifications
The sizes
Dimensions of body (DhSHhV), mm 4690 x 1695 x 1525
Dimensions of interior (DhSHhV), mm 1865 x 1435 x 1185
Wheel base, mm 2575
Distance between lobbies / back wheels, mm 1450 / 1465
Height of a road gleam (klirens), mm 175
Weight without passengers, kg 1390
Weight with passengers, kg
Number of places 5
Number of doors 5
The minimal radius of a turn, m 5.3
Volume of a fuel tank, l 60
The engine
Mark of engine FE-ZE
The maximal capacity, h.p. / rpm 165 ps (121.36 kw) / 6500 rpm
The maximal moment, N*m * (kg*m)/rpm 19.2 kg*m (188.29 N*m) / 4500 rpm
Specific capacity (kg / h.p., weight / capacity) 8.42
Type of engine Water cooling serial 4 cylinder DOHC16 valve
Dop.informatsija about the engine
Type of submission of fuel Electrically controlled gasoline injection type
Turbine No
Used fuel Unleaded premium gasoline
System of decrease in quantity of harmful emissions (LEV) No
Degree of compression 10
Diameter of the piston, mm 86
Course of the piston, mm 86
Transfer number of the main pair
The charge of fuel in city, ë/100 km (by the new machine!) 8.4
The charge of fuel behind city, ë/100 km (by the new machine!)
Suspension bracket / the Running part
The hydraulic booster of rudder Yes
Forward wheels 195/65r15 91s
Back wheels 195/65r15 91s
Forward brakes Ventilated disk
Back brakes Disk
Forward suspension bracket Strut type independent suspension
Back suspension bracket Strut type independent suspension
The equipment
External equipment
The hatch
Forward antifog headlights
Back antifog headlights
Ksenonovye headlights
Lamp-projector
Cleaner of a back glass
Forward spoiler
Back spoiler
Antiblocking system (ABS)
Antiprobuksovochnaja system (TCS)
Automatic differential with blocking (LSD)
Tonirovannye glasses
Protection against ultra-violet beams on glasses
Aluminium wheel disks 15 inch standard
Internal equipment
Conditioner Full automatic
Furnish of interior " under a tree "
The cruise-control
The central lock
Electric steklopodemniki
Mobility of a steering column forward-back
Mobility of a steering column upwards-downwards
Leather braid of a sterring wheel
The electric drive of forward seats
The electric drive of back seats
Leather seats
Displayed back seat Divided type
Belts for a children's seat
Belts for a back seat
Tension belts on a forward seat
Rigidly fixed belts on a forward seat
Amplifiers of rigidity in doors
Pillow of safety driver's
Pillow of safety passenger
Pillow of safety lateral
Audio AM/FM radio equipped cassette player
CD - plejer
System of navigation
- Is - is not present - an option
Discussion Starter · #2 · (Edited)
thanks for the translation C.
more understandable this way.
Revolution is a good recreational activity
anarchyx34 said:
"Pillow of safety"
ROTFL...:D
I think that's what they call "airbags" in the northeast US
Same like "Amplifiers of rigidity" translates to "Viagra"
Or something.
Oh, I knew what it meant. I just thought the extremely literal translation was quite funny. :)
i wouldn't be beliving that site TOO much. they are in hot water over importing down in Russia, the business was closed the site got moved to Auto.Vl.ru.
there are better sites out there forinformation. just ask
Freddie, i dont take much on the web as accurate.
Thats why i will find things out for myself
This new fe that i have will prob get a dyno run in non turbo form, just to see how much hp it has.
I know how hard the steel sump goes, just want to check this alloy one.
I think its a waste to not find out its original potential, before turboing it.
Then i can see if it has 170 hp, as some are claimed to have.
From memory, the engine number is FE 999139. Now you claim to be able to tell alot from there numbers, so here is your chance..........
its a 97+ engine, should have 10.0 compression, no EGR, should have VICS on it. then again it could be FE-DE.
when you get it have a look at the cams
None i have seen have EGR's. But they have had VICS.
One thing that is weird. the spark plug cover is bolted down with bolts, not nuts..
It has the ported Vics chamber and is a "Ford" FE
It has a 4 wire o2. Minimal vac lines .
Discussion Starter · #13 ·
Thanks for posting the pictures, Trip.
As you can make out. its a Ford badged FE and you can also see the valve cover is bolted etc.
The injector loom is 8 pin only and the ECU is the 2 plug/conector version. FEFE.
all fords were bolted intead of dome nuts.
ECU is a later one. in later models (F2 or Fe) they went with ATX combined ECUs. ATXs had three plugs and MTXs had two.
i have a 98 model ECU lying around from a Crouse-R model (apparently top perfromance and Luxury :rolleyes: , ugly as sin though) GVII Cargo. FENJ code and two plugs. also interesting point is that some later model FEs used KF airflow meeter, still MAF but KF. as well as i have a FE5A ECU.
the other day i came across FEXX4, the 4 is half the size of FEXX........ i have no idea where that one came from but it was used as a door stop :D
Discussion Starter · #15 ·
all ford are not bolted.
as the other one i bought, wasn't......
1 - 15 of 15 Posts
