When you take of the steering wheel there should be a little white plastic ring with some little pins on it. On yours those pins problably broke off, that's why it doesn't shut off anymore. Just replace the ring (with one from an mx6 or an rx7 - I'm guessing those are the same) and it should work fine.monoxidechild said:i have a 91 rx7 wheel installed. only issue is my blinker dont shut off when i turn, i need to do it myself.
not the issue, ive re-installed the stock one, and they work fine, its definitly an issue with the RX7 wheel itself. but ive gotten used to it, i dont even think about it anymoreRadinov said:When you take of the steering wheel there should be a little white plastic ring with some little pins on it. On yours those pins problably broke off.
Maybe the rx7 steering wheel has a bigger offset so the pins wont hook into the wheel or something like that...monoxidechild said:not the issue, ive re-installed the stock one, and they work fine, its definitly an issue with the RX7 wheel itself. but ive gotten used to it, i dont even think about it anymore
