21 - 40 of 1336 Posts
well today was just too damn hot... and 000mx6... i thought the 2.2L was supposed to be alot faster... not just a little :p and if only i got traction *thinking smiley*... that other 1st gen we saw looked good... but didn't look too fast... i mean, i did catch up again LOL... that was fun....
*Selva in no way condones street racing, it is extreemly dangerous and fun... but do not try it... or at least dont blame me :p
ok 1 more...
I gotta Defend myself here, well about as much as i can...
I did stop to wait for the gold AR, he neva came... so i took off looking for the beach, turns out i was right the first time... was heading up the road, saw Goldy popped a u-turn when it was clear... and lost him again :(... after that, was my own stupidity...
errrr.... just a q, is 12 psi safe for the AS Turbo? or should i just stay on 8? im not too fussed with the life of the engine, as it's not really that good anyway.... also, did the FE3 come out turbo? coz that AR looked phatt and i was thinking of importing a FE3t if possible...
FE3 never came in turbo. And it would need a lot of $$$ to be turbod properly, also your aware of how much work it is to convert to the FE3, right? Not hard but very fiddly. Also the F2T has around 28% more power than the AS FE-T. However the F2T is a much more advanced engine with much more potential because of the factory components (ie. Computer Controlled Ignition, Multipoint Fuel Injection, 12V Head). Its not hard to get a 150KW out of an F2T with the right modifications, thats around a 47% Increase over the original FE-T, this is possible with $2.5k (using s/h parts ofcourse)
As for your car, you could try 12PSI but id think it may lean out, as I know if my car (F2T) isnt running up to scratch will ping on 12PSI, and that has 4 injectors, not one!
Try and see, but beware you could crack a piston from too much boost and/or leaning out.
Good Luck :tup:
Hey Selva since that was you I saw in Virginia, would that also be your TX5 I see in Two Wells regulary? If so look out for the white AT TX5 thats low, or a champagne silver 626GT with P Plates :)
yeah i am in tw every now and then, but not too often, you would prolly have more luck spotting my gf (Menace Purple TX3 Laser with a PHATT bk)... and i think i have seen yours... i have my TX5 running richer then normal so it's not a big fan of idling smooth, but all i need to do is idle it up to the 950 - 1000rpm mark and it's smooth as... whats the work involved in doing a FE2t conv.? and would anyone be willing to help? i can do all the mechanical work easy... but the wiring would be for someone else...
EDIT - What about the mpfi system off the 929t? the way a RWD sits with the mani facing the front of the engine would make a FMIC easier to put on... that and it has 4 injectors :p
MATE! let me defend myself here!!! sorry to give your hopes up but didnt you here me crunch second gear...thats probably why you kept up like you did....if i would have executed second gear nicely i would have "cained" you!!! hehehe but no excuses you kept up!
000mx6 how dare you. You made him think the FE-T is acutually good :p
Seriously though go for a ride in a F2T powered one and its f'kn ON :D
ok 1 more...
I did stop to wait for the gold AR, he neva came... so i took off looking for the beach, turns out i was right the first time... was heading up the road, saw Goldy popped a u-turn when it was clear... and lost him again :(... after that, was my own stupidity....
Sorry about that! I missed the Waitpinga road turnoff then lost the group. After going into the wrong beach I tried to call PSI but there was no signal. When we went back onto the main road we saw you and thought you were sent back by the group to find us so we kept on cruising. I was almost gonna pull over but it was 50m to the proper beach turnoff so I just kept going. Next time i'll pull over.
As for the FE3 idea its all about money. As TX5Turbo said they are reasnobly cheap to import at $1850 but then its fiddly stuff. The good news is that you have EFI already, so no surge tank and fuel lines like I had to. However you will need to weld up an alternator bracket, different front piece of exhaust, fit different airbox, wiring, possibly remote battery...... Its not hugely difficult stuff but its just costly in the fact of time and buying lots and lots of little cheap things that add up to a fair total.
Turboing the FE3 is quite difficult. Nobody makes turbo manifolds so you would have to pay an engineer to make one for you. Then depending on how much boost you run there is lower compression, O-ring head gaskets, new engine management etc etc etc..... Thats why ive left mine N/A for the time. For an N/A 4-cylinder its got some good power. There is no question that this would then make 300-350HP if done with a good turbo and good engine management, however the extra cost compared to an F2t is significant.
I dont know how you would go about fitting an F2t into the AS chassis. They use a different top engine mount so you would need to get that welded onto the chassis near the washer overflow tank. Or maybe the FET uses this mount already? I dont recall seeing it when I looked at your engine.
The best part of the F2t is that its already turbo, ready to go. Cheap easy power, and there is heaps of them in the country. The trick to wiring is to grab everything off a wreck and label where it came from and just "put it in" your car. Saves a lot of headache.
Man that was a long post.....
Discussion Starter #29
Ive decided to leave the ride hight alone and just live with it, not a fan of cutting or resetting the springs, any how they may drop 10mm anyway im told. the funny thing is the hight between the road and bottom of the car is the same at both ends of the car its just the gap between the wheel and arch thats different, besides im not sure if i want the Midnight Club Dub Edition look on my car, maybe my next car will.......:confused:
Discussion Starter #30
Hey hows this, on the way home from work last night i was on the expressway and following this van when we passed a tow truck picking up a broken down car. I could not belive what i was seeing when some guy reached out the side of the van and chucked his beer bottle at the tow truck, it hit the cabin and smashed all over the expressway. i had no choice to drive over it or cause another accident. looked like the people in the van thought it was quite funny and they started picking up speed (120-130ks) i took 3 secs to think bugger that no one desevers a bottle hiting them at over 100ks, i took off after it to get the rego and details, with in no time at all i got his van type, colour and rego then headed home.
As soon as i got home i rang the cops to find out the tow truck had just called them but he did not have any details on what van it was or the rego plate.
All the details i gave macthed up woo hoo!
i see this similar type of crap all the time on the roads so it feels boddy good to catch these wankers once and a while!!!
god i hate those kind of ppl! i had some dickwad throw a maccas cup at me in my TX3, i turned around and almost run them over coz they ran out in front of me... then they started chasing me in there commonwhore (NA TX3 v VN... you figure it out!) so i bolted... as they had 2 full cars chasing little ol me... and later that night i blew me clutch (have pics) so yeah... it was a good night :(...
and the AT/V telstars (even with the FE) have a different front mount to the AR/S, and they modified the damn block, not the mount???? FTW??? so modifications will be ness. how ever modifying things isn't a problem for me... (my last project was BP motor into a BD 323, it all went in, but then it turned out to be too much of a headfuck :( )...
And ok 000mx6, you did grind second, but you did get traction off the line, however i did not (damn shyte retreads!) so either way we'll call a f'ups even ok? but you still beat me... *mutter* I need that FE2t and 12psi... or more...
Peace Out...
Selva.
When you say FE2T im assuming you are talking about the F2T yes?
As fair as I knew the AS TURBO had a FE-T. Unless im on the wrong track :)
AS / GC turbo had the FE/T
AT / GD turbo had the F2/T
your mother
her sister
and your father in a bikini
all sitting in a circle on the grass
FE2t F2t... you know what i meant, means the same anyway...
Discussion Starter #37
i could search it but i think its something like a vj11, or i could be totally wrong so best advice would be to search it. I know Dion will know so once hes on he will soon tell ya lol:p
It is the IHI RHB52KW series.
VJ11 for the F2T
VJ-5 for the FE-T
how do you tell the difference between the FE and the F2? sorry so many questions lol also does anyone know who makes this turbo? thinking of getting a rebuild for the hell of it
The FE and F2 is the engine
FE-T SOHC 8V single point injection (2.0L)
F2T SOHC 12V Multipoint injection (2.2L)
you have the F2T, and your turbo is a IHI VJ11
