Does anyone know if the Pacesetter cat-back pipes will hook up to a stock/stock-sized muffler? I have the pacesetter exhaust taking up space in my garage, and I was thinking of using the pipes from the pacesetter with my Ansa muffler. Any advise/comments would be appreciated.
Thanks
What's the inlet size on the Ansa? If it's anything less than the size on the pacesetter, which I believe is 2.5"s it would be kinda pointless.
I think that the inlet size of the Ansa is set up to hook up to the stock exhaust, so it's probably the stock size. The thing is that I have crappy crimp-bent pipes from Kragen, from the cat to the muffler. I figured that if the pacesetter pipes fit, then since they are mandrel bent and larger diameter, then they would flow better.
