I have my timing light and everything, but can anyone give me the procedure for setting the timing on a 2.5 liter 1994 mazda mx6
jump the ten and grd pins and time it as ussual
Reactions: steelersfan
Discussion Starter #3
Im not sure how to time it as ussual
I just need the whole procedure from start to finish thanks
Let the car warm up fully, then jump the 10 and grnd pins in the diagnostics box and hook the inductive sensor for the timing light to the #1 spark plug wire (closest to the passenger door). Hook the + and - to the battery for the timing light and fire away at the crank pulley. You want to be at 10btdc (which is marked on the timing plate).
