I have installed a shaved door handle kit. The problem is that the fuses keep blowing. Would anyone know why this is hapening? Perhaps they have been installed incorrectly. Would anyone know how to install them?
Sounds like you have a short somewhere? How did you have them wired to the door? is any raw edge cutting through the wire?
nitro balla>> you can get a good kit off ebay for about $100... make sure to get the 35 lb solenoid kit.
Well, I got a 50lbs solenoid off the web. I dont remember where. I didn't see any raw edges, but i'll look again. the wires are running from the fuse box to the solenoid.
do they only blow when you actuate them? what is the rating on the fuse? what wire are you using? what is the rated draw of the solenoid?
